Re: Super M stuck really hard
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Glenn on February 23, 2000 at 07:59:23 from (199.196.144.43):
In Reply to: Super M stuck really hard posted by Tim Ham on February 22, 2000 at 18:36:15:
If it's stuck THAT bad, you should probably take the engine out and have the pistons pressed out at a machine shop. You'll wind up replacing the sleeves anyway, and that way you can have the block hot-tanked and checked.
Post A Followup
: Re: Re: Super M stuck really hard
