Re: I'll let you all troubleshoot this one.
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by HR on February 23, 2000 at 08:35:45 from (63.253.193.185):
In Reply to: I'll let you all troubleshoot this one. posted by The Red on February 23, 2000 at 06:19:18:
The Red: I tend to substitute systems to isolate the source of a problem.. I may have tried to disconnect the gas line and hooked in a small tank of even just one gallon of new\clean gas. One gallon will run ya around the yard quite a while. If it ran good, then the original fuel system has to be bad. Sounds like your about there anyway. Good luck. harvey
Post A Followup
: Re: Re: I'll let you all troubleshoot this one.
