Re: Ihc Combine Ihc tractors
Posted by chuck46 on December 01, 2007 at 20:35:40 from (64.136.27.229):
In Reply to: Ihc Combine Ihc tractors posted by Frank Slater on December 01, 2007 at 14:33:29:
Hi Frank, There is not a lot that I am aware of. The combines use the industrial engines, many components will interchange but it takes some work to put a combine engine in a tractor. Combine engines run at higher rpm's than tractors. The hydraulic system from a combine is very usefull for putting power steering or hydraulic valves on an older tractor. The hyd. pumps could be usefull but they are not the same as any tractor. Good luck, Chuck
