Re: Well, you warned me...
Posted by glennster on December 02, 2007 at 10:56:17 from (68.60.242.156):
In Reply to: Well, you warned me... posted by Mike CA on December 01, 2007 at 16:14:49:
when you get and extra 150 or so laying around mike, order the rebuild kit from carter and gruenwald. has all the bearings, bushings and seals for the front bolster. the bushings can be pressed in or if you can find a sleeve puller , you can put them in that way. there is a seal in the bottom of the upper bolster that holds the oil in. before you put the main shaft back in, clean the sealing surface on the shaft with fine emery cloth or install a speedy sleeve on it. or just leave it and use corn head grease. or not. choices, choices, choices.
