Re: Wesendorf (sp?) loader on M with regular hydraulics.
Posted by gene bender on December 02, 2007 at 12:05:28 from (67.55.226.214):
In Reply to: Re: Wesendorf (sp?) loader on M with regular hydraulics. posted by Carl Grover on December 02, 2007 at 09:52:54:
Probably has a built in resivour if it has its own valves. Jus hook hy line from the right side below the beltpulley to the in side of the valve assy. You should have another hose from return on valve assy or the built in res. You will need a tee on the standpipe of the res on the tractor. To make the valves work pull back the lever on the tractor and lock it back this moves hy fluid from thactor pump thru the valves to make them work. You mite need to get someone to help do this that has some experience in hy systems.
