Re: Super H, In too deep
Posted by GeneMO on December 02, 2007 at 12:23:34 from (216.74.196.145):
In Reply to: Re: Super H, In too deep posted by GordoSD on December 02, 2007 at 06:13:02:
Your replys made me feel a lot better. I dont think I slept good last night just thinking about the cost involved if I had to replace it.
I am glad now I took it this far apart. The rear engine seals must be bad also as there is a lot of oil and dirt in the belly pump casting and behind the flywheel.
Anything else I should do while I have it split and the flywheel off?
I am replacing all the seals in the front of the transmission also.
Thanks again,, Gene
