Re: Cub Running Poorly
Posted by billde on December 03, 2007 at 07:17:21 from (72.26.91.191):
In Reply to: Cub Running Poorly posted by Brian in MA on December 03, 2007 at 06:58:40:
Sounds like you are running out of fuel. Pull the drain plug out of the carb, turn the fuel on, let it run for 4 or 5 minutes.
collect the gas in a container of course.
If the fuel flow diminishes you have a restriction. It has to be in the carb screen or the sediment bowl assembly.
You don't by chance have an inline filter?
