Re: Farmall A no power
Posted by Nat 2 on December 03, 2007 at 14:47:24 from (64.80.108.52):
In Reply to: Farmall A no power posted by The Dukester on December 03, 2007 at 14:27:17:
What all did you do, specifically?
First off, if you did rings, pistons, bearings, etc, have you done the engine breakin yet?
Have you checked the compression after the overhaul?
Is the timing set properly?
Carburetor too lean?
Really, I expect this to be a governor problem. Either it's not adjusted right or it's not working at all. Low compression engines don't start "great" or run like "a bear."
