Posted by gene bender on December 03, 2007 at 18:49:35 from (67.55.226.214):
In Reply to: Re: hand crank posted by Hugh MacKay on December 03, 2007 at 18:27:16:
Hugh i found out you have to have the long crank on a B or BN if you have the 221 cult as it is the steerable model and the short crank wont work because of the linkage isnt that where the long and short cranks started and over the yrs got mixed up on the different models.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
