Re: Cold Weather Starting of 350 Diesel-Advise please
Posted by Michael Soldan on December 04, 2007 at 11:48:30 from (24.235.47.91):
In Reply to: Cold Weather Starting of 350 Diesel-Advise please posted by migraine on December 04, 2007 at 10:24:53:
Well, I always start my diesels in cold weather with the throttle pulled wide open. Some tractors have certain features to help, for instance a 584 , you hold your fuel shut off lever out halfway and it provides more fuel to aid in starting. The batteries are very important. They need to be Good and be charged up. I've seen folks starting a diesel and complaining about the hard start when in fact it is turning over, but not turning over fast enough.Good batteries are a must.Ether is better left in the can. Some kind of heater will help, I have a magnetic one I clamp on the oilpan, you can stick it on the water jacket if you wish, the extra bit of heat helps a lot.On the oil pan it thins the cold oil and the heat does permeate the combustion chambers, an in line coolant heater is likely the best.Run some methyl hydrate in the diesel fuel and a quart of automatic transmission fluid in the fuel will lube your pump .That's what works for me, but battery is 90% of the start up.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
