When bearings are the same as for an M this are the ones:
The Bower bearing on end of upper shaft can be replaced with a common SKF NU 2205 ECP.Replaces the Bower 5205. Pilot Clutch 6205-2R. Rest of gears upper shaft and lower shaft:SKF6211 under upper SKF6311. Site of the bellypump undershaft 6305-NR-R.One rubber seal to prevent leaking and help the seal to the bellypump a little.They can be mounted in tandem with alittle grease bewteen.See for all this www.skf.com. Also the bigger ones in the rear are on them.I had to replace one.I thought in 6330 or 6325?
All can easyly bought on ebay.com or ebay.de for not much. Very nice internetsite you made.I like the shop too!!!!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
