Re: IH 484 Differential lock pedal stuck
Posted by Michael Soldan on December 04, 2007 at 18:59:02 from (24.235.47.91):
In Reply to: IH 484 Differential lock pedal stuck posted by jhppe on December 04, 2007 at 18:51:53:
Look underneath..the pedal activates a small piston like rod which is sticking and not moving freely out of the housing. Spray it with penetrating oil or some kind of good oil lubricant. Move the tractor ahead slowly and stomp your left brake pedal, then your right..this sometimes lets the differential lock release. Soak the oil to it, then just work the diff lock pedal with your hand , up and down..multiple times until the oil is worked into the seam around the piston collar.
