Re: 484 with issues
Posted by georgeky on December 04, 2007 at 20:24:15 from (64.12.116.73):
In Reply to: 484 with issues posted by Noel Putman on December 04, 2007 at 17:01:06:
Bleeding the brakes is a temporary fix at best. Brakes are the weakest point on the 84 series tractors. They work really well until they start leaking off. It needs some new o rings in the system. The axles have to be removed to get to them. If they don't leak to much bleeding will make them work perfect for a while, but you will be bleeding them from time to time. The engine speed is llikely dirt in the tank and or fuel lines. They tend to stop up at the fittings on bottom side of tank. Those and the cross over line likely need to be cleaned and new fuel filters.
