Re: H seal needs to be done
Posted by glennster on December 05, 2007 at 12:28:41 from (99.131.143.56):
In Reply to: H seal needs to be done posted by Pat-CT on December 05, 2007 at 12:18:56:
that looks like the drive for the belly pump coming out of the trans. i use a brass punch and a hammer to knock that loose, pretty sure it unscrews counterclockwise. then pop the seal out, and replace the seal. i pack my seals with grease where the spring goes around the rubber lip. that way the spring dont pop out when you tap the new seal in. i dont remeber if you need to take the three bolts out and remove that cover. been a while since i changed one. randy aka neblinc just did the one on his h maybe he will chime in!!!
