Re: H seal needs to be done
Posted by neblinc on December 05, 2007 at 12:30:36 from (76.79.15.57):
In Reply to: H seal needs to be done posted by Pat-CT on December 05, 2007 at 12:18:56:
Pat, that should be an easy fix. That piece unscrews counterclockwise, if you are lucky it will tap loose.
Find a a bar or punch that will fit the slot and give it a few good taps.
Once unscrewed, remove the 3 bolts on the housing and replace the seal with a new gasket.
Check the drive dog when you remove it for any wear grooves caused by the bad seal, the new one a lot smaller so you want to try and position the seal so it misses that groove if there is one.
Lots of pics on my website link below.
Randy
