Re: Super M stuck really hard
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Dale Groskreutz on February 23, 2000 at 12:56:10 from (206.10.72.131):
In Reply to: Super M stuck really hard posted by Tim Ham on February 22, 2000 at 18:36:15:
Tim, the grease gun trick really works. Go to a cylinder where the valves are closed and the piston is close to the top. If there is no water in the oil pan you have a chance. Also take the valve cover off first and make sure the valves are loose or you could break one. Good Luck
Post A Followup
: Re: Re: Super M stuck really hard
