Re: H bull pinion bearing
Posted by Nebraska Cowman on December 06, 2007 at 11:18:29 from (65.162.146.41):
In Reply to: H bull pinion bearing posted by riverbend on December 05, 2007 at 18:45:16:
Sure.This is an M but it's the same thing. take the capscrews out of the retainer and the big one on the gear end of the shaft and the axle will slide out how ever far you want. I had the lid off this one to get some gears but you can do it through the PTO hole. And if the tractor is headed downhill you don't even have to drain the grease.
third party image
