Posted by LenNH on December 06, 2007 at 11:26:52 from (75.69.99.42):
In Reply to: 1938 F-20 road gears posted by Scott Rukke on December 05, 2007 at 07:40:25:
As to the pin to lock out the road gear, I can't speak for the F-20. Almost certainly, IH sold tractors with factory-installed road gear ONLY on rubber tires. These became available pretty commonly after about 1936 (first, the round-spoked wheels, then about 1938 with those beautiful cast-iron wheels). I do know that there is a lockout "pin" on the H and M. During WW II, the use of rubber tires on tractors was restricted, and IH simply put a long bolt through the top of the transmission case of the H and M to keep the 4th-5th gear rail from sliding forward into 5th gear. A tractor that came that way could be "converted" to a 5-speed transmission in about 2 minutes by turning the bolt out far enough to let the rail move forward. I am pretty sure that tractors that came from the factory with 5 speeds just had a short bolt into the transmission at this point. Naturally, if somebody wanted to lock the tractor out of fifth gear, he could put a longer bolt through this hole. My father probably should have done this with me. I sure did like to roar up and down the roads on our H. But maybe by then I was a mature-enough teenager not to upset the thing on sharp corners in the road.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
