Re: damaged H differential
Posted by D Slater on December 06, 2007 at 14:55:05 from (72.65.140.68):
In Reply to: damaged H differential posted by riverbend on December 06, 2007 at 13:37:50:
Looks like the part that the differential bearing goes on is broke off or worn off. You need another one.
