Re: Farmall hood emblem off a 140
Posted by Hugh MacKay on December 06, 2007 at 15:42:27 from (64.228.11.133):
In Reply to: Farmall hood emblem off a 140 posted by craigreavley on December 06, 2007 at 08:16:30:
Craig: You are talking about older 140 with metal decals, correct? I'm quite certain 240 is the same as 140. I know 460 and 560 are much larger. I'd almost bet there were only 2 sizes, thus the split will be between 4 and 6 cylinder. I haven't seen a 340 in years, but I'll bet it is the same.
If I'm wrong, you'll find out much quicker than if I had said nothing. This is afterall about getting you the right answer.
