Re: damaged H differential
Posted by Roger46 on December 06, 2007 at 17:13:29 from (69.58.143.196):
In Reply to: damaged H differential posted by riverbend on December 06, 2007 at 13:37:50:
Greg, Looks like you need a different differential. When you replace it you need to redo the gear mesh and backlash adjustments. This can take some time to do, but if you don't do it and the gears aren't correctly meshing it will damage them and make a lot of noise. I replaced the gear case on my Cub and it took a lot of trial and error to get the correct adjustment. Any shop manual for the H will give the procedure. Roger
