Re: H starter problems
Posted by Bob M on December 06, 2007 at 18:49:55 from (69.205.120.58):
In Reply to: H starter problems posted by Illinois Farmall on December 06, 2007 at 15:55:34:
I agree with Gene Bender - sounds like a bad cable.
I had similar problems with my Super M last Sunday. Turned out that while the cables looked fine, corrosion hidden under the insulation on the ground cable had eaten away almost all the copper near the battery clamp end.
After installing a new ground cable the starter now spins like new.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
