Re: international 856 steering problem
Posted by Bradford on December 06, 2007 at 19:27:22 from (76.30.247.168):
In Reply to: international 856 steering problem posted by ben poirier on December 06, 2007 at 17:59:28:
My 826 was real bad still needs some MCV pump help. But it is a lot better becuase of two things.
Make sure both front tires have 44 pounds of air
and make sure both thrust bearings are working correctly.
Also, jack up the front end and see if the hydraulics are helping at all. and if it is loose.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
