Farmall A 100 130 control valve instructions
Posted by Steve Couvillion on December 06, 2007 at 19:58:31 from (209.33.2.64):
Anyone have a set of the overhaul kit instructions to properly replace o rings & gaskets on the hydraulic control valve used on A / SA / 100 / 130 ??
Looks like there are some needle valve under some allen head screws. Do they come out first ? or last ?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
