Re: IH 315 combine engine removal
Posted by Chuck46 on December 06, 2007 at 20:33:30 from (64.136.27.229):
In Reply to: IH 315 combine engine removal posted by smdv806 on December 06, 2007 at 18:50:01:
Hi SMDV, It is very basic, I take the radiator and the pulleys and housing from the rear first just to get them out of the way. Also the hydraulic pump you won't be using, take the manifold, you won't be using that either. Then you will have good places to anchor chains to lift it off. You realize this is the 221 engine like the 460. Good luck, Chuck
