Re: IHC diesel
Posted by Dave H (MI) on March 07, 2009 at 16:59:20 from (64.12.116.73):
In Reply to: IHC diesel posted by Alwaysafarmer on March 07, 2009 at 14:09:08:
Yes, heads were prone to cracking if they were not operated per instructions...I have heard it was the shutdown procedure that was most important but then again I have had others tell me different. I have one of these in my small collection and have done a little research on operation. Mine needs service and I have put it off a little too long now. There is a lever you operate to switch it to diesel and, if memory serves me, this closes off the plugs and changes it around so it will combust diesel under pressure. That is the best I can tell you and I would definitely recommend that you do a search for more and better info. These engines are very interesting. If you stand on the right side of the tractor you are looking at a gasoline engine setup. Move to the left side and it looks like a diesel. Do the recommended search.
