THe backlash can be adjusted at anytime. The issue is tooth and bearing/bushing wear. If the teeth are looked at with a hand maginfying glass, and there3 is little pitting (spalling from lack of lube/rust water and humidity from no operation for long periods) no micro dents (brenelling is caused by hard broken buts of metal betweem parts)and the drive flank has little if any wear showing, the gears are probably servicable. If the bushings and thrust washers are clean scar free, and have only .001 to .003" clearance (AN APPROXIMATION) It is good to go. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
