Re: fast hitch implements
Posted by glennster on December 07, 2007 at 13:21:57 from (99.131.143.56):
In Reply to: Re: fast hitch implements posted by georgeky on December 07, 2007 at 13:17:00:
i gotta tell ya george, i been fooling around with this 240 i just picked up, got the back blade and bush hog. that fast hitch is the berries!!!! it sure beats the heck out of the 3 point hookup, on , off, back up, pull foreward, kick it, swear at it, drop the lynch pins......that fast hitch, back in, and go!!! pull the rope from the operator station, drop it and go again.....i gotta get some more implements for this little bugger.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
