Re: 574 D value
Posted by Harold Hubbard on December 08, 2007 at 04:29:50 from (199.232.228.77):
In Reply to: Re: 574 D value posted by RayIn on December 07, 2007 at 20:12:35:
Also make sure there is no fuel leaking from between the saddle tank and the fenders, especially if it looks like it spent a lot of it's life shoveling manure. Moisture and acids get down in that seam and rot through the tank.
Check the parking brake. Usually they get left on and burned up. You can figure at least a day to replace it.
