like georgeky said check the front rims, be sure they are centered. run one of the front tires up on a couple 2x6's so the other is off the ground, spin the wheel and look for out of round, it may just need to be centered better. while its up there check to see if the rim has any side to side wobble, could be the rim is bent. check the mounting holes in the hub to see if they are wallered out to. if so you may need to either put bushings in the holes, or redrill for the next larger bolt. (ace hardware usually has a good selection of various bushings) true value too. check both front wheels.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
