Re: fast hitch implements
Posted by migraineh on December 08, 2007 at 08:44:15 from (67.182.151.248):
In Reply to: fast hitch implements posted by dc5724 on December 07, 2007 at 12:19:37:
I have been collecting fast hitch implements for several years now. Have 1 pt plows and 1 pt rototiller. then 2 pt plows. Have three 2 bottom plows including one rollover, two 3 bottom, and a 4 bottom. Have two sickle mowers, a 2 pt subsoiler, 2pt disc, 2pt blades (one small prong, two big prong )2pt carrier, and a two way plow. I use these on 100, 200, 230, 300, 350 450, and 560 tractors, and think they are the handiest implements to hook up and use. They are getting hard to find in good shape and not modified to 3 pt. I have three 2pt to 3pt conversions to use with some other implements but prefer the 2pt. When we used the 4 bottoms back in the 60's though it was hard to keep the draft control set right in hard ground and you needed lots of weight on the front ends when you pulled it out of the ground. I just think it was an idea a bit before its time . I just got a 240 utility with loader on it but need a hood and white louvered engine skirts if anyone has these lying around for sale. Thanks Migraine
