Re: .040 bearings for farmall M
Posted by L.C.Gray on December 08, 2007 at 11:25:51 from (208.193.186.139):
In Reply to: .040 bearings for farmall M posted by Mike Farmer on December 08, 2007 at 11:11:43:
I'm not saying its impossible by any means but it probably wouldn't survive the long haul
As much trouble as it is to have the crank out, I believe I'd look for another crank that would grind .030 and go with it.
If you do try the shim deal, be sure to account for oil passage on the block side and take a little off the ends of the bearing shells so they don't bottom out on one another. Also check your fit with some plastigage. Sometimes 1 and 1 don't always add up to 2 under load.
I still say find another crank, you're already in too deep to be "southern engineering" something so critical.
