Re: 49 H, negative ground?
Posted by CNKS on December 08, 2007 at 11:49:51 from (216.144.104.128):
In Reply to: 49 H, negative ground? posted by EH in KS on December 08, 2007 at 09:53:02:
The wires at the distributer need to be reversed if you go to positive ground. If it is currently charging ok, the only potential problem you may have with negative ground is that if your current voltage regulator is designed for positive ground (you will have to remove it and see if it is marked), the contacts will wear faster. Otherwise you can change it to + or leave it as is.
