Re: 49 H, negative ground?
Posted by John T on December 08, 2007 at 12:31:16 from (66.244.83.147):
In Reply to: Re: 49 H, negative ground? posted by L.C.Gray on December 08, 2007 at 11:16:13:
1) Since the starter is a series wound DC motor that uses an elecromagentic field versus a permanent magnetic field IT STILL TURNS THE SAME DIRECTION REGARDLESS since youre not swapping the field or armature windings with relation to each other. A permanent magnet motor would reverse cuz you change the current direction in ONLY ONE of the field or armature i.e. the armature since the magnetic North/South polarity of the permanent magnet field remains unchanged
2) If its a battery powered coil igntion it still fires even at reverse poalrity but its not near as efficeint and wont deliver as much spark gap energy across the plug gap as if its wired correct i.e. swap leads if you reverse polarity
3) If it has an ammeter its leads need reversed if you swap polarity otherwise it reads bass ackwards.
4) The genny can still charge fine regardless of polarity BUTTTTTTTT it needs repolarized
5) Many Voltage Regulators will work at EITHER polarity while others may not. Thinks like polarity sensitive suppressor diodes and the coatings on relay contatcs can make a difference. If its not labeled Id go ahed n try it cuz it may work fine a long time but if it quits you need a new correct polarity one anyway.
6) Points or condensor dont care nor light bulbs
7) SOME gauges are polarity sensitive IF THEY USE GALVO NEEDLE ACTIONS while the bimetallic heat type dotn care which direction the current flows
Any other polarity questions??
yall take care n God Bless
John T
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
