Re: .040 bearings for farmall M
Posted by the Unforgiven on December 08, 2007 at 12:36:15 from (66.146.249.116):
In Reply to: .040 bearings for farmall M posted by Mike Farmer on December 08, 2007 at 11:11:43:
No, it will not work. You are thinkig of picking up the extra .010 on the outside of the bearing shell, and you need to think in terms of the inside. The 30 under bearing is thinner, to fit around a certain size shaft. So, when you shim the back of the insert and wrap it around a smaller shaft it will act like it is too long and also be squeezed out of round near it's ends. Because the outer diameter of the insert HAS TO BE the same no matter what the inner sizing is.Forget it, send your crank to China, and get a different one.
