Starters will drag after years of use. Likely the brushes and or bushings are worn out in the starter. You may have better luck putting the 12 volt battery directly to the starter instead of trying to jump it off jumper cables. They tend to loose a lot of amps in the process. The 20 below should not stop it from starting if everything is in order. I have started mine many times at those temps. In fact when it gets that cold here the M's and C's are about the only things that go. I don't even try to start the diesels when it is that cold.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
