Posted by gene bender on December 08, 2007 at 17:13:50 from (67.55.226.214):
In Reply to: Timing a MAG posted by rdb on December 08, 2007 at 17:03:31:
First thing before the mag is installed turn it over and with the cap off make sure the rotor lines up with the tower on the cap when it fires. Then when you have #1 on the compression tdc you can install having the rotor pointed to the wire going to #1. Since the drive is a slotted type thing the worst you can be off is 180deg. With the plugs out and using the cramk you can determine if you have installed it correct by turning engine over and watching when it impulses. There is no advancing timing as it will impulse on tdc then when engine runs it will go to 34deg advance nothing in between good luck.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
