Re: .040 bearings for farmall M
Posted by Janicholson on December 08, 2007 at 17:50:26 from (66.173.50.153):
In Reply to: .040 bearings for farmall M posted by Mike Farmer on December 08, 2007 at 11:11:43:
I agree with Bus Driver and D Slater,
Shimming for fit was common practice even as late as the 70s, but only in the area of .0005 to .002 (very max) The solution is to have the crank welded as indicated in their post. A welded crank, with standard bearings will make it trustworthy in your mind. Shimmed up bearings will never be trusted with the full faith that the rebuild needs to have. Plasma Spray technology is incredible. JimN
