Re: Cleaning an H Gas Tank
Posted by Andy Martin on December 09, 2007 at 06:17:57 from (63.99.111.189):
In Reply to: Cleaning an H Gas Tank posted by Doug Kieta on December 09, 2007 at 06:02:10:
If gas won't cut it (and it won't cut old solidified gasoline) I would open a hole from the bottom to let gas through. I've used a drill bit in my hand.
Then I install an inline fuel filter to catch bits of hard material and put the tractor in service. Eventually you will find the light ends in new gasoline will dissolve the old deposits but it takes years. In the interim, the inline filter keeps the carburetor clean.
I have done several tractors this way and rarely have to change the inline filter. If you are a purist replace the entire fuel line so you can reinstall it later. Likely it is not the factory fuel line anyway.
If you follow the other advice you will get here, you are in for a long effort to get everything cleaned out from behind the baffle in teh tank. Once you put in a solvent to soften the deposits you have to get it all out or it will bedevil you for years.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
