Re: what Ya'll been up to?
Posted by Hugh MacKay on December 09, 2007 at 10:23:08 from (216.208.58.120):
In Reply to: what Ya'll been up to? posted by Gary in Mozarks on December 09, 2007 at 09:29:26:
Gary: There you go, I knew when I kicked you 3 weeks ago, you'd find your way back to the YT flock. I'm assuming the car port is done, you've hung up the carpenter tools, and your back to tractoring.
I know you have hytran in the 460, probably not cold enough yet to blame the weather. 460 and 560 were quite prone to having pump failure after water and dirt. I know you had quite a bit of both after you bought the 460. Problem here that filter can starve the pump if pluged or water saturated bad enough, therein lies the cause for your damage.
