Year ago I designed and built an oil reclaim system for an ammonia refrigeration plant. It worked very well and Texaco said the oil met new specs when tested. You need a vessel,(small hot water tank) small oil pump with motor, cheap air compressor, and some spin on oil filters with mounting hardware and a bunch of pipe fittings.
The compressor was used to pull a vacuum on the system (hook up the intake to the tank) which lowers the boiling point. Set the thermostat on the hot water tank to 140-160 so the oil does not overheat and degrade or form carbon. The pump circulates the oil through the tank and filters. This system was used to reclaim about a barrel a week of contaminated oil which would otherwise be lost. A fair bit of work to set it up for a one shot deal but you do not have the marital problem with oil on the kitchen stove in her best pots. Karl
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
