Re: I'll let you all troubleshoot this one.
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by werf on February 23, 2000 at 17:52:04 from (216.145.222.31):
In Reply to: I'll let you all troubleshoot this one. posted by The Red on February 23, 2000 at 06:19:18:
Have you checked to see if there is a fuel filter at the carb inlet.It would be behind the nut thet the fuel screws into(use a 1" wrench to remove). Some times they will hold water, and when the gas goes through it causes the water to freeze. Also if you question the line, just get a long piece of hose to put in place while your checking it out(don't leave hose as a line replacement). Good luck.
Post A Followup
: Re: Re: I'll let you all troubleshoot this one.
