I use 2 5/8 bolts with the heads cut off and 2 flats ground on the end to help remove if needed for help with alingment of center section to rear. The transmission input shaft and its housing bolts to center housing with or without T/A and the outside of that housing fits in the big hole in transmission to take care of final alingment. The transmission main shaft front roller bearing slides inside transmission input shaft, on reassembly some recommend putting a rubber band around rollers to hold them closer. I usualy remove belt pulley gear box or cover and reach roller bearing and lift front of main shaft to line up because transmission main shaft drops a little without input installed. Most 450 have just the splined coupler for the pto shaft,if so the splines need lined up also when installing center to rear. If it has the seasonal disconnect just set in disconnect position when installing housing. Before removing center housing from transmission take out 9- 5/8 diameter bolts( not head size), one is inside the T shaped cover plate on bottom of center housing. If you don't know how parts are removed from center housing you should get a manual or someones web site that shows how.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
