IH 300 Utility IPTO binding
Posted by Mark Ciotoli on December 10, 2007 at 11:46:15 from (72.68.93.165):
I added an IPTO to a 300u that never had one. Donor tractor was 300u also. Unbolted the back plate to check bands-both were not frozen-some wear but still a ways to go before needing replacing. New gaskets and oil seal were installed. Bolted it in place-the problem is the pto shaft is very hard to turn, even with both bands adjusted very loose-it doesn't free wheel at all-engine turns with it at all times. I have read the archives, this seems to be a new problem or more likely I did something wrong. Thanks in advance for your help.
