Re: .040 bearings for farmall M
Posted by RustyFarmall on December 10, 2007 at 12:44:04 from (216.248.71.93):
In Reply to: .040 bearings for farmall M posted by Mike Farmer on December 10, 2007 at 12:35:42:
Do what you think is best, but be advised that when those "shimmed" bearings fail, not only will the crankshaft be destroyed, but the chances are pretty good that the connecting rods will also be damaged beyond repair, and there is a very real chance that one of those rods might take a shortcut to the outside world right through the engine block. If you want to see expensive, try finding another engine block with a good crank and rods still in it.
