Re: .040 bearings for farmall M
Posted by Owen Aaland on December 10, 2007 at 13:40:29 from (65.165.246.41):
In Reply to: .040 bearings for farmall M posted by Mike Farmer on December 08, 2007 at 11:11:43:
Tapered shim stock use to be available just for shimming behind bearing shells. To take up .002, the shim stock would be .002 in the center and .001 on each end. You only shimmed one bearing shell, not both. You put the shim under the main cap shell so that the block side with the oil hole was still original.
If done carefully there should be no reason that shimming .030 bearings to fit a .040 shaft will not give good service. The biggest problems will be finding shim stock in .005 size and in taking off .005 on each end of each bearing shell and keeping the ends square.
