Re: .040 bearings for farmall M
Posted by Janicholson on December 10, 2007 at 14:58:26 from (66.173.50.137):
In Reply to: .040 bearings for farmall M posted by Mike Farmer on December 10, 2007 at 12:35:42:
Bearings for another application is a great solution if you have a real engine parts person at hand. Other than that, I'll bet it will be just fine.
Use steel for the shim, mate the oil holes and make them really match well. Put the bearings in the block very clean and determine the amount of crush on the existing setup, Remove material only from the side that has no tab to get the bearings back to that crush distance. Too much, and it distorts the bearing at the parting line, too little and it is spin city. I built a lawn mower engine by turning the rod journal on a lathe, then making an insert out of T-6 aluminum. It ran for 12 seasons before a different issue killed it. JimN
