Re: 1206 Questions/help...Thanks
Posted by JayIHMan on December 10, 2007 at 16:49:57 from (70.247.210.144):
In Reply to: 1206 Questions/help...Thanks posted by perrycountyfarmalls on December 10, 2007 at 15:13:14:
I agree if it has TA don't pull unit...Even if the unit has no TA I would not recomend pull starting it...How will you stop unit if it starts if the clutch cannot be disengaged. I work on units all the time like this and sometimes you can get in trouble fast. Try cranking it in neutral to start and be safe.
