Re: Cleaning an H Gas Tank
Posted by CityBoy-McCoy on December 10, 2007 at 17:27:54 from (209.214.107.14):
In Reply to: Cleaning an H Gas Tank posted by Doug Kieta on December 09, 2007 at 06:02:10:
I did not want to take mine to a radiator shop because they boil it out and it takes the paint off the ourside of the tank, meaning I then would have to repaint the tank and it would never match the rest of the paint on the tractor. So, I bought 5 gals of Berryhill Carburetor Cleaner. I removed the tank from the tractor. I pluged the sediment bowl hole with a fitting. I poured about 2.5 gals of the carb cleaner in the tank. I swished the tank around several times a day. Let it stay in there about 24 hours. Poured the carb cleaner back into the can it came in so I could used it for other jobs. Rinsed out tank with water and let it soak in sun for a couple of hours to totally dry. It worked great. Total cost: $75 for Berryhill carb cleaner, which I still have for carb building, etc. Metal inside tank is very clean and no sealer is needed. mike
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
