True there low RPM, but if worked hard with a 5-1/4 inch stroke and only 3 main bearings and putting out more torque than most V 8 engines did until recent years or what some big blocks used to I don't think I would shim, but its his tractor and may be okay for his use. Maybe because I have seen the results of what happens when a center main bearing spins is affecting my opinion. It not only damages block behind bearing, but also the thrust part of block that thrust sides of bearing contact.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
